Ok ive done just under 2K in my 323i and used about 500ml oil, is this too much for a 125K engine?
Problem is I cant see where its going, its not in the exhaust or the coolant so whats going on?
Where is my oil going
Artis
stem seels might be on way out
Widge
Hmmm so you may end up using 5 ltrs in 10,000 miles of motoring.
Are you sure the sump plug is not leaking?
k130
cheers, ill check that, one of the lower breather vacuum hoses has shattered, could it be that?
Widge
Yes!!!!!!!
I bet that's what it is. Better that than expensive engine internals
k130
too right mate
anyway she wouldnt run so well if she was pissing oil into the cylinders...
Widge
Asking questions you already know the answers to!!!!!
Hmmmf whatever is next
