cabrio roof replacement
I have a 320i '88 convertible which needs a new roof.
Found a car for sale, not mechanically sound but with a good roof. How easy is it just to take off roof and put it on my car? Will there be any problems with leaks or wind noise, it should just bolt onto my car no problems?
Also how easy would it be to take out it's central locking system and fit it to my car?
Cheers.
Cheers.
- orangecurry
not done it myself, but it is supposed to be easy to take the frame/roof out - BMW recommend doing this for a long winter.... if you have a hardtop...
but there are shims/washers which make the roof line up... so if you are putting in a 'new' frame, it will take some effort to get it right, as you are supposed to note how many shims come off of each bolt, and put it back exactly the same.... but your 'new' frame will be slightly different, won't it?!
There are also adustments you can make to the windows if necessary.
Good luck!
Good luck!
- orangecurry
apparently to make the frame line up perfectly, each attaching-to-the-body bolt/stud can have shims/washers added to allow adjustment...
hey I explained that clearly didn't I?
Have you got a 'Bentleys'? There are two nuts and two bolts to remove from each side... you undo them after lowering the hood.
If there are any shims, they will be sitting on the horizontal bolts/studs.
Clear as mud?
Clear as mud?
Ok I got you, no Bentleys just a Haynes but there are only a few bolts so can't be that difficult and once its fitted will just be a case of ironing out all the wee niggles and potential leaking points.
Cheers for the help.
- orangecurry
I'm trying to get my scanner to work grrrrrr
if I can resurrect it, I'll bung some Bentleys pages up.
- orangecurry
can yow see these?
*link removed/images/convtop-p1.jpg
*link removed/images/convtop-p2.jpg
*link removed/images/convtop-p3.jpg
do a rightmouse 'save picture as' jpeg, as I may remove them at some point in the future with a wave of my mouse
**edit - I'll take the links out then.... copyright? It was like that when I got here, Officer.
- orangecurry
You're welcome.
Turin eh...do you get to go up to Cervina skiing? <sigh> It's one of my favorite resorts... took my girlfriend-turned-wife there years ago.
Going up there in an E30 in the snow would be *special*.
I was up in Cervinia last year in the snow, not the best weather for a cabrio and it's fun with RWD! 1 metre of snow over night and I could barely see the car in the morning.
It's good with the cabrio in Italy but it's impossible finding parts, only see 5 or so other e30 cabs in over 1 year in Turin!
Is there a pub called the RED DRAGON still there..brings back memories..
try this link
http://www.worlduph.com/topbmwinstructions.htm
or
http://www.behindmatrix.com/e30/fotost/ ... f00213.htm
try this link
or
let us know how you get on..
the red dragon used to be run by and english girl married to some called pellisier..
do they still have a bob run,,,i went down as part of s a team (i was a replacement) I have never been so scared
