induction kit
hi guys just want to find out will an induction filter from a 318i e30 fit on a 320i e30
mrLEE30
assuking its a "cone" filter held on by a jubilee clip yes but dont bother as the factory designed airbox and filter are more than adequate for the job. better quality filters are available to replace the factory item.
fitting an "induction kit" will nromally only result in sucking in warm ari from the engine bay rather than cool air as directed to the standard air box through the hose behind the headlight, the solution to this is to make a heat sheild.
