Interior light question
pac1982
Thu Jan 21, 2010 1:12 pm
Having just fitted a alarm system with remote central locking i was wondering if there was a way I could get the interior lights to come on when I unlock the car as opposed to them coming on only when I open the door?
I have read something before about a light delay module that sits near the central locking computer do I need one of these of is there a way I can do it without one of these?
robbo86
Thu Jan 21, 2010 4:48 pm
Beleive it was an option on the E30 and the relay for it just plugs straight in.
**BANNED**
Thu Jan 21, 2010 5:13 pm
My interior light delay units work the other way round,lock the car and walk away and all your mates start yelling that the interior light is still on....then it fades out.... :P
Youth is wasted on the young.
pac1982
Thu Jan 21, 2010 8:59 pm
daimlerman wrote:My interior light delay units work the other way round,lock the car and walk away and all your mates start yelling that the interior light is still on....then it fades out.... :P
Hmmm seems to the OE unit does the reverse of what I’m after, don’t suppose any clever people know of an easy solution to gain the desired effect??
robbo86
Thu Jan 21, 2010 10:37 pm
There was some fell adapting the OE unit to give a gradual delay in the states and posting them over here. That was on the old zone though and he hasnt been on in an age before that! It can be modified yourself but thats beyond me.
clipper
Thu Jan 21, 2010 10:50 pm
Maybe a stupid question, but can't you adapt a module from a car which does this as standard, like an E39 ?
Sanchez
Thu Jan 21, 2010 10:55 pm
Does your alarm trigger the hazard lights?
If so change the wiring so that it give power to the interior lights instead, hey presto when you arm or disarm the alarm the interior lights will light instead of the indicators.
E30k
Thu Jan 21, 2010 11:50 pm
yes you can do this first you need the said module plus a switch/relay that can take the signal from your alarm to make the module work but the light will go out after a set time also it will not be a simple plug in and play setup as far as i can tell
Fri Jan 22, 2010 9:18 am
If you have an interior light delay module fitted, it should be possible to achieve what you want by connecting the unlock pulse output of the alarm to the door pin input of the delay module. You would need to fit a blocking diode in the wire, and another one in the existing door pin wire.
pac1982
Fri Jan 22, 2010 11:50 am
Hmmm ok then first step is o fid one of these interior light delay modules, are thy expensive, still availble from the stealer etc??
1990 BMW E30 318IS (Sold)
1990 BMW E30 316i (RIP)
Fri Jan 22, 2010 6:47 pm
Delay modules aren't that common in the UK, but they're not exactly rare either.
Try an ad. in parts wanted.
Same module was used in some E28 models as well.
