5 stud conversion using E36 parts
Basically, the m3 evo stuff, provides more castor to help re-centre the wheel. If you want to use standard e36 stuff, you can. All you will need is some custom made wishbones, which are available from e30 centre darlaston, which push the wheel back into the centre without having to use the m3 hubs and m3 evo wishbones. £100 a pair.
- Brianmoooore
Interesting!FMH wrote: All you will need is some custom made wishbones, which are available from e30 centre darlaston, which push the wheel back into the centre without having to use the m3 hubs and m3 evo wishbones. £100 a pair.
Can't find a website for this place.
Also the M3 Evo stuff would be uprated, better brakes etc.
E30 Centre in Darlaston, don't think they got a website, known for there expertise in convertible roofs.
07968 852395 Bill
07871 662902 Jason
07968 852395 Bill
07871 662902 Jason
mick_318is
Anyone using these custom made wishbones??
- Brianmoooore
Probably, but my stocks of bog standard E36 stuff are somewhat greater than those of M3 evo bits!ImysE30 wrote:Also the M3 Evo stuff would be uprated, better brakes etc.
That's interesting.FMH wrote:Basically, the m3 evo stuff, provides more castor to help re-centre the wheel. If you want to use standard e36 stuff, you can. All you will need is some custom made wishbones, which are available from e30 centre darlaston, which push the wheel back into the centre without having to use the m3 hubs and m3 evo wishbones. £100 a pair.
Thanks for your reply.
