tec 1 kit on a facelift
age
Formerly twist316
Post Thu Jan 07, 2010 12:17 pm
can this be done and if so is there alot of modification to be done
thanks
Post Thu Jan 07, 2010 12:28 pm
Side skirts will fit pretty much dirrectly on.
Front tech 1 valence will require the whole prefacelift front end bolted on so, metal front valence, bumper mounts, bumper, plastic under tray, fog lights etc.
Rear tech 1 valence requires more work to get it to fit. You will need the bumper and mounts and im sure the metal rear panel behind and below the standard rear bumper need to be played arround with.
age
Formerly twist316
Post Thu Jan 07, 2010 12:29 pm
do you think its worth it or will i just go and buy a prefacelift
Post Thu Jan 07, 2010 12:30 pm
Buy a pre facelift as all you will end up with is a mutant.
Post Thu Jan 07, 2010 1:44 pm
don't do it they look rubbish
