Ways to make the power steering less strenuous to turn?
haffeel
Mon Aug 22, 2005 11:30 am
I find my power steering little hard to turn.
What can I do to make it as smooth and effortless even baby can turn it :wink:
My car is just new rebuilt, installed a new steering coupling to get rid of the slack as I was feeling like floating when at speed above Kms 60
some one said, I need a new steering pump?
Well, I would like to hear from the forumers?
cheers/haffeel
Karan
Mon Aug 22, 2005 11:46 am
if anything i find it too light!
Simon
Mon Aug 22, 2005 11:47 am
:gay:
:lol:
Mon Aug 22, 2005 11:55 am
I find mine quite heavy too
Gonna change the fluid first as it looks a bit grim! If that don't cure it then I will live with it as it had a reconditioned rack 3 years ago.
There is a guide in the articles section that tells you how to change the fluid.
Turbo-Brown
Boost Junkie
Mon Aug 22, 2005 1:30 pm
Bunch of wusses! :lol:
Some of us have manual steering and are planning to change to 2.5 turn racks in the not too distant future too!
BrAdZ
Mon Aug 22, 2005 3:21 pm
I Like it as it is...... but i would like less turns lock to lock
Martinaston
Mon Aug 22, 2005 3:40 pm
Get down the gym :lol:
There is NO nucleus.
Hyperion
Mon Aug 22, 2005 4:26 pm
The steering on the E30's are a bit hard, but thatÔš's how they are supposed to be. the power assist only helps a little bit(parking, low speed manoeuvring etc.), it becomes quite light as you speed up.
Templ8e30
Mon Aug 22, 2005 5:57 pm
My missus 316i had light power steering. When I changed the knackered leaky rack I stripped the old one and found that someone had done a mod.
There is a rectangular (ish) plate on the front of the rack held on by 2 bolts, it sits in front of the pinion from the steering column. Remove this plate and insert a thin washer behind it.
This applies more force to the pressure regulator spring resulting in a higher hydraulic pressure giving lighter steering.
It works because she complained that the new rack was heavier so I fitted this washer to the new rack and it became lighter again.
I can't find a pic of a rack but if someone has one post it up and I'll circle the relevant plate. Pretty certain it's the only plate on the rack.
Cheers,
Iain T
2007 Mazda 6 2.0 estate
haffeel
Mon Aug 22, 2005 11:46 pm
Hi Templ8e30,
I am sure many will thank you, if we can get this thing right. Please send a photo of the location of the Bush to be inserted.
TQ
cheers
astondg
Tue Aug 23, 2005 12:34 am
I think mine is too light. Although I just had a friend drive it:
Friend: "The steering is..."
Me: "Yeah it's too light."
Friend: "No, it's too heavy."
:lol:
Aston
BMW E30 323i with some stuff
1:21.67 @ Morgan Park Raceway
Rearwheel_nick
Tue Aug 23, 2005 12:38 am
you lazy cunt :wink:
Jackle
Tue Aug 23, 2005 1:43 am
I find my PAS quite heavy too, good for parking, but gets quite heavy when going along. Seems to get really stiff at the centre position and needs a bit of effort to move it off centre. Also get a creking when I turn the wheel to the right, most noticable when doing a tight turn at low speed. Any ideas what this might be?
I'm going to change the fluid and see if that helps.
Skar
Tue Aug 23, 2005 5:42 am
recently i had a loud creaking noise (sounds like crickets) coming from directly behind my steering wheel, the steering felt heavy at times and hard to turn, i apply some grease to the bearing and it worked. its been 2 weeks and there isnt any noise so far and steering is smooth now.
Stoney_god
Tue Aug 23, 2005 9:19 am
haffeel wrote:I find my power steering little hard to turn.
cheers/haffeel
Pump your tyres up to 100 PSI !!!! :lol: :lol: :lol: :lol:
haffeel
Tue Aug 23, 2005 5:03 pm
stoney_god,
Pray tell me which brand tire I should use as well :x
:ban:
Martinaston
Tue Aug 23, 2005 7:03 pm
Templ8e30
"I can't find a pic of a rack but if someone has one post it up and I'll circle the relevant plate. Pretty certain it's the only plate on the rack."
This is an old steel rack from an M20 so the 316/318 ali one is different.
Templ8e30
Wed Aug 24, 2005 4:04 pm
Ok thanks for the picture.
I've highlighted the cover and reposted below.
Remove the cover and fit a standard thickness 10mm steel washer under the cover on top of the pressure relief plunger/spring. Job done.
The plate is in the same place on the alloy 4 cylinder racks too.
Cheers,
Iain T
JoeP
Location: The Bunge, Waveney Valley, Norfolk/Suffolk border
Wed Aug 24, 2005 4:10 pm
Turbo-Brown wrote:Bunch of wusses! :lol:
How is it? Did you just disconnect the pump, is it easy? I live in the country so don't do that much tight manouvering.
My girlfriend has a mk1 MR2 which just has the greatest (unassisted) steering feel which I'd like to replicate as much as possible.
Alpine White 325i touring
Saying 'No' to saloon and cabriolet wrongness :-)
Turbo-Brown
Boost Junkie
Thu Aug 25, 2005 8:24 am
It's fine as soon as you get moving. Literally half a mile an hour makes the steering bearably light.
My car never had PAS ('85 325i) so there aren't any connections on the rack for the pipes or anything.
The steering does have quite a nice weight to it when you do get moving, but also still has the arm twirling 4.75(ish) turns lock to lock!
haffeel
Thu Aug 25, 2005 2:23 pm
hi Templ8e30 thanks, I will give a try with the washer. is it OK 1mm thickness washer?
Great JOB Templ8e30,
thank You,
haffeel
Templ8e30
Thu Aug 25, 2005 2:56 pm
Yes 1 or 2mm thickness washer is perfect.
Let us know how you get on.
Cheers,
Iain T
haffeel
Wed Sep 07, 2005 6:34 am
I changed the steering fluid filter inside the big bottle container to check the level together with new steering fluid.
Now my steering is much easier.
I used DX III oil from FUCHS
tomstickland
Wed Sep 07, 2005 10:44 am
Pump front tyres up to 32psi.
I disconnected the PAS pump on mine and it's not too heavy really. You want a bit of weight there so you can feel what's happening. Might as well drive a Corsa otherwise.
Wed Sep 07, 2005 10:49 pm
E30BeemerLad wrote:I find mine quite heavy too
yours is heavy mate cos of the 17 inch wheels
my car has light steering when i have 15's on, then when i put my pina 16's on it adds a nice weight to the steering imo.
E30 racks don't like big wheels and it knackers them alot quicker than using 14's,15's or 16's tbh
Gwynleym10
Wed Sep 07, 2005 10:53 pm
Also don't knackered track rod ends or tie rod ends mess up stearing?
If your stearing is to heavy, pump your front tyres up an bit or get tyres with lower width i.e 50 as opposed to 55.
If its to light do the opposite!
Dual wheel carriers -------195litre Fuel Tank
London 2 Cape Town
www.Overlandinthesun.com
Wed Sep 07, 2005 11:10 pm
A couple of years ago, while driving my wife's touring, I realised that it's steering seemed to be noticably heavier than mine.
Got it on the ramp and disconnected the track rod ends. Found the right hand strut was very stiff to turn.
Immediately jumped to the wrong conclusion that the top mount was seized. When I ureleased the outer ball joint on the control arm to remove the strut, it all suddenly freed up. Joint could hardly be moved by hand, although the rubber cap was intact, and under it was shiney and greased.
gaszman
Sun Sep 19, 2010 1:18 pm
could you use another washer the same as the 1 thats allready in the rack so you could have 2
bmw9818
Sun Sep 19, 2010 3:06 pm
my pumps gone and its very heavy, gives your arms a nice workout though,
tari
Mon Sep 20, 2010 10:49 am
When doing this washer mod, does any fluid leak? I doubt it but just making sure!
