Hi
I am still stuck with the indicator clicking with key in aux posisition
has anyone got a diagram explaining the fuses and relays on 316i 94
All help appreciated
Bob
Fuses and relays
bob53
E30 Touring 316i 1994
E32 730i V8 1993
E32 730i V8 1993
A1BMW325iSport
have you tried replacing the relay?
bob53
Yes I have changed relay and hazzard switch
been out this morning and removed dash and ecu but no difference.
Bob
Bob
E32 730i V8 1993
E32 730i V8 1993
A1BMW325iSport
please explain the exact symtoms and any other faults you have
bob53
Hi
check out my other post
http://www.e30zone.co.uk/modules.php?na ... ic&t=15375
http://www.e30zone.co.uk/modules.php?na ... ic&t=15470
Basically the indicator relay is operating as soon as the key is turned although the lights are not
the flashers still work when switched.
Bob
Bob
E32 730i V8 1993
E32 730i V8 1993
A1BMW325iSport
most obvious thought is wire from switch to relay shorted to ign live
