Wed Dec 23, 2009 10:31 pm
I have similar problem with my 1988 320i, it comes to life everytime, but 90% of the time I have to sit for about 10 seconds cranking it on the starter while pressing the throttle, somethimes I find a sweetspot on the throttle and it kicks into life instantly, but mostly I end up just giving it WOT until it fires.
Temparture dependancy is not really an issue, it's all the time.
I have checked the coldstart temperature sensor and it works fine.
This summer I had a reaccurring failure readout stating that the ECU didn't have contact with injector number 6. But after having the injector part of the wiring loom out and refitted it stopped with this failure. But the starting issue hasn't changed.
I suspect the plug that connects the injector wiring to the main engine loom to be the problem. One of my friends has had some difficulties with his 325i engine due to this plug. And in the end his mechanic soldered all the wires together and binned the plug. Since then no problems.
Why is there not enough time to do it right, but allways enough time to fix the errors - I borrowed that, just so reallistic in my line of work.
