slidey bracket thingy on 318 gear box
AndyBird
the 2 bolts which hold the gearbox up i can do 1 up but the other is spinning because they are on that gay square bit on the back any suggestions?
Ant
- Retired Team Member
if you have removed one already, slide the functioning jam nut alongside the one thats spinning, add a washer and tighten fully, you should be able to remove the duff one easily afterwards dude.
alternative method..... use a flat tip screwdriver and jam the bugger with the tip.
all else fails, grind the head off, new ones are not Ԛ£
Email FTW
