m42 318is help needed.
E30GAV
Tue Dec 08, 2009 2:56 pm
hi guys got an issue with my car.
use to be a 316i. . . .then dropped in the m42.
use to run well, had abit of an idle problem and use to cut out here and there, wasnt that bad.
just got the car back on road, on cold start up the car is fine, u can rev her and when the revs come back down it will idle again no problems.
but then when shes warmed up, evrytime the revs coms down so it can idle it coughs and just dies out. this is only happning when shes warmed up.
i didnt put this engine in my self, but looking at the exhaust i cant see the lambda sensor on there, and there is a small round plug in the engine bay which i assume it connects to.
could this be the problem??? im not enjoying driving the car at all.
pac1982
Tue Dec 08, 2009 3:00 pm
have a good look at all the pipe work could have a crack somewhere
1990 BMW E30 318IS (Sold)
1990 BMW E30 316i (RIP)
Saga
Tue Dec 08, 2009 3:35 pm
My -is downpipes were not plumbed for an 02 sensor. This may be why you can't see an 02 sensor (not being cheeky!).
Are you using the DME to match the M42?
E30GAV wrote:hi guys got an issue with my car.
E30GAV
Tue Dec 08, 2009 3:53 pm
what do you mean by DME?
the rubber intake boot that connects to the air flow seems to have small hair line cracks. but this was like this before, and it still use to run alrite.
Saga
Tue Dec 08, 2009 5:09 pm
E30GAV wrote:what do you mean by DME?
DME = ECU. Silver box o' tricks containing PCBs, another 3-letter acronym.
Edit - Stating the obvious, but that boot may still have a split which isn't evident to the naked eye.
asmith88
Tue Dec 08, 2009 6:24 pm
does the plug which isnt connected, have one splitting off, also going to the afm and the tps?
if so it isnt required on NON-CAT cars
1990 brilliant red 318 is
E30GAV
Tue Dec 08, 2009 6:53 pm
yes i got the ecu with the engine. . . .which was fitted.
il check with the plugs, but there is one that goes to the AFM which is currently conneted. the plug that im on about is near the battery, comes off the loom near there.
DHFiS
Tue Dec 08, 2009 9:01 pm
AFAIK the M42 for the UK market does not have a lambda sensor
pac1982
Tue Dec 08, 2009 9:03 pm
DHFiS wrote:AFAIK the M42 for the UK market does not have a lambda sensor
Mine dont have a lambda or a cat and its a 1990
asmith88
Tue Dec 08, 2009 10:00 pm
snap
E30GAV
Tue Dec 08, 2009 10:41 pm
rite i take it mine doesnt hav one eitha, the engine was from a 1990 aswell. rite il try changin the rubber intake boot that goes on the afm.
Dave_M3
Tue Dec 08, 2009 11:33 pm
Could be the temp sensor playing up by still thinking the car is cold and therefore letting the car run excessively rich which causes the car to cough and die out when returning to idle after throttle has been opened
E30GAV
Wed Dec 09, 2009 3:16 am
i heard about this temp sensor before . . . is it the blue one by any chance???
Wed Dec 09, 2009 9:57 am
All M42 engines are designed to be used with or without a lambda sensor. If a sensor isn't used, there is a plug and socket in a white/black wire under the bulkhead wiring cover, near the middle, which must be pushed together.
