slight rumble in the car???
325dude
allo all sme again my 318 has a slight rumble in the car when driving the car just had a mot and the wheel bearings were fine i am sure i can feel it throught the steering wheel hmmmmmmmmm could it be a missing wheel weight?????
johnono
is the rumble on a bend or while u are going straight?
do u feel it more under breaking or is it constant?
is the rumbling a drone type noise or more of a vibrating judder?
does it lessen with speed?
325dude
well its worse the fater you go but apart from that it seems constant i thoght it was a whhel bearing but we checked and the car had just gone thru a mot by my local garage and i know that the wouldnt miss somthing like that??? its an odd one i can feel it thru the steering as well and its on a power sterring rack ..............................j
johnono
would still feel it even with pas. have u changed breaks recent?
mabey ure disks r warped. if the droning is from the back, see if u have a diff leak
mrLEE30
could also be your prop shaft centre cross bearing. that usually creates a droneing sound and a judder usually noticable at certain speeds.
