Elephants Trunk!!
RegTourist
Sun Nov 29, 2009 7:15 pm
Can anyone explain how I check the elephants trunk to see if its blocked????
pac1982
Sun Nov 29, 2009 7:17 pm
i think your mates may be taking the piss out of you matey
1990 BMW E30 318IS (Sold)
1990 BMW E30 316i (RIP)
Sun Nov 29, 2009 7:18 pm
eko
Old timer
Sun Nov 29, 2009 7:19 pm
Its located on the bulkhead next to the battery tray.Just twist it off and clear it out,if it doesnt crumble in your hand that is.
pac1982
prehaps i was wrong :o:
pac1982
Sun Nov 29, 2009 7:20 pm
what does this do then??
gareth
Sun Nov 29, 2009 7:46 pm
it's a drain pipe
pac1982
gareth wrote:it's a drain pipe
I guessed that but what does it drain??
gareth
Sun Nov 29, 2009 7:56 pm
the scuttle area afaik
oomz1975
Sun Nov 29, 2009 8:00 pm
Just pull it off, its not screwed in or anything.
AlpineAde
Sun Nov 29, 2009 8:30 pm
And they can be a bugger to refit. Whack it in a bucket of hot water to make it pliable and reseat it as was.
Sun Nov 29, 2009 8:39 pm
gareth wrote:the scuttle area afaik
Drains the central area. The alternative drain path is through the heater box, and out of the air outlets, onto your carpet.
nickso
Sun Nov 29, 2009 10:07 pm
surely it would drain through the offside wing before it got that far?
'88 e30 328i M52 track bint.
Sun Nov 29, 2009 10:09 pm
nope , carpet it is :(
nickso
Sun Nov 29, 2009 11:00 pm
e30topless wrote:
nickso wrote:
Brianmoooore wrote:Drains the central area. The alternative drain path is through the heater box, and out of the air outlets, onto your carpet.
theres not much of a ridge to get over to the nearside drain though......admittedly i cant remember what the height of the air intake is in comparison.
DavieP
Sun Nov 29, 2009 11:20 pm
Too right it does! Almost had a paddling pool in the driver's footwell caused by this after the heavy rains we've had recently. It's quite surprising to see how much crud can build up in there.
Dave in Torquay
Mon Nov 30, 2009 12:03 am
nickso wrote:
e30topless wrote:
nickso wrote: surely it would drain through the offside wing before it got that far?
Probably would drain to the right if the car is level, but any slope to the left, and carpet it is!
nickso
Mon Nov 30, 2009 12:10 am
Brianmoooore wrote:
nickso wrote:
e30topless wrote: nope , carpet it is :(
good point, never thought of that.
RegTourist
Mon Nov 30, 2009 3:16 pm
nickso wrote:
Brianmoooore wrote:
nickso wrote: theres not much of a ridge to get over to the nearside drain though......admittedly i cant remember what the height of the air intake is in comparison.
Thanks for that ......great site to become a member of! :cool:
djscottfree
Mon Nov 30, 2009 5:02 pm
that elephant trunk took me nearly an hour to put back on, bloody thing, there wasnt even any dirt in there ! i was going to give up and finally it popped on was a struggle tho, i recommend heating it up in hot water, or rub a bit of oil round the lip :)
**BANNED**
Mon Nov 30, 2009 6:24 pm
djscottfree wrote:that elephant trunk took me nearly an hour to put back on, bloody thing, there wasnt even any dirt in there ! i was going to give up and finally it popped on was a struggle tho, i recommend heating it up in hot water, or rub a bit of oil round the lip :)
Soft soap is your friend for this sort of thing.
Youth is wasted on the young.
dazleeds
old skool raver
old skool raver
Mon Nov 30, 2009 6:33 pm
pac1982 wrote:i think your mates may be taking the pee pee out of you matey
:hammer: :bolt:
www.oldskoolfantasy.co.uk
