Here is what real oem shows for my 320...non cat.
A bit confusing....
Yes ok, in some peoples opion, but when others (& NGK) come along and say..Simon13 wrote:get it?!mrcool wrote:OK mine is 88 320 and going by the book that is ZGR5A. I see some people swear by the BPR6ES tho..
It contradicts that and makes things more confusing. So are you saying it doesn't matter if its early or late, cat or non-cat. The early plug should be used still ?jay528ise1985 wrote:ZGR5A are meant for later (approx '87 on) 320 & 325 and have a projected nose so the spark is placed further into the air/fuel mixture, apparently increasing efficiency and having the added benefit that the tip is cooled by the incoming air/fuel mixture during the induction stroke to a greater degree.
I am using these plugs on my 2.7 27 6E B/731 (many people say they don't work with the high compression of the 2.7 conversions), they remain almost immaculately clean with a pale brown colour and no signs of overheating, glazing or cracking.
To summarise: Superb plugs! (In my opinion/experience)
