engine hicup
stevo
Sat Aug 13, 2005 3:59 pm
whats happening is the engine jerks every so often, at any rev, wether its being driven or at idle
i thought this was due to a split hose on the idle control valve but i sorted that today and the problems still there, i also noticed the oil filler neck is slightly sucking in so checked the breathers and they're clear. they're doesnt apear to be any leaks anywhere either. ive also tried disconnecting the battery for an hour but still nothing :cry:
there doesnt seem to be any loss of power otherwise
does this sound familiar to anyone?
please help :(
its a 318i m40
orkboss
Sat Aug 13, 2005 7:18 pm
Is this a jerk or just an odd miss when the engine fails to fire. Mine has done this.
stevo
Sat Aug 13, 2005 7:31 pm
its like it gets no feul for a second, as if ive took my foot off the throttle and press it again straight away, or if its ideling the revs will suddenly dip until the engines on the verge of cutting out then return to normal.
think i'll give the fuel filter a check, if thats possible?
jonmsm
Sat Aug 13, 2005 7:40 pm
have you tried looking at the idle control valve??
I am not sure if the e30's have them but the e28's have them and they can cause an irregular idle.
Also, it could be the fuel pump... its possible its on its way out or a bad earth on a power lead for the pump?!
Jon
1986 e28 M535i (gone and missed)
1988 e30 320i cab (full resto STILL in progress)
1996 Volvo 850 T-5 estate (280bhp Turbo Nutter), T-5R (my precious)
1966 Fiat 850 saloon & 1970 Sport Coupe
C1 (go-kart)
stevo
Sat Aug 13, 2005 7:44 pm
the ICV looks ok, i'll give the feul pump connections a check and clean up though, never thought of that :thumb:
jonbuoy
Sat Aug 13, 2005 7:50 pm
What's your car like when starting up from cold?
stevo
Sat Aug 13, 2005 7:51 pm
starts with no problems at all
Sat Aug 13, 2005 7:54 pm
how do i get to the fuel pump on my 325?
In the last week it has suddenly got a lumpy idle and at low speeds with your foot just on the gas it kangaroos a little
jonbuoy
Sat Aug 13, 2005 7:55 pm
Yeah but what about idle? Does it still do it then(idle up and down, and a bit sh*tty til warmed up)?
stevo
Sat Aug 13, 2005 7:56 pm
think its inside the fuel tank :roll:
jonbuoy
Sat Aug 13, 2005 7:57 pm
E30BeemerLad wrote:how do i get to the fuel pump on my 325?
Try cleaning your idle control valve
Sat Aug 13, 2005 7:58 pm
what do you do mate, just give it a blast with some carb cleaner?
stevo
jonbuoy wrote:Yeah but what about idle? Does it still do it then(idle up and down, and a bit sh*tty til warmed up)?
yeah the revs kind of fluctuate a few times on start up but its always done that, this "hiccup" doesnt happen then though
stevo
Sat Aug 13, 2005 8:01 pm
E30BeemerLad wrote:what do you do mate, just give it a blast with some carb cleaner?
think it can be accesed from under the rear seat, not really clued up on it though, and i think the gasket wil need replaced if its removed. just flicking through haynes at the mo'
:oops: not reading the post right :roll:
jonbuoy
Sat Aug 13, 2005 8:03 pm
Has your car ever overheated at one stage? I have the same problem and have been told to change the temperature senser as this is tell the ecu that the engine is warm when it's actually cold.
jonbuoy
Sat Aug 13, 2005 8:06 pm
Yes mate, you are right. Spray cleaner in one end with finger over the other hole, fill it up and give it a good shake. Do this a couple of times and should be ok mate.
stevo
Sat Aug 13, 2005 8:07 pm
jonbuoy wrote:Has your car ever overheated at one stage? I have the same problem and have been told to change the temperature senser as this is tell the ecu that the engine is warm when it's actually cold.
a couple of times, but not since last year, this only started happening after i serviced it. is the temp sensor deer?
jonbuoy
Sat Aug 13, 2005 8:10 pm
Same happened with mine really, did'nt start mucking me around till a mth or 2 after it happened. I was gonna change mine today but did'nt get the bloody chance as the bloody father inlaw dragged me up the club, willingly :lol: ................not sure about the price tho but make sure you read through your manual about it if your not fluent. Chapter 3-7 Temp gauge sender unit
Sat Aug 13, 2005 8:11 pm
by temp sensor we mean the one on the thermostat housing?
stevo
Sat Aug 13, 2005 8:14 pm
jonbuoy wrote:Same happened with mine really, did'nt start mucking me around till a mth or 2 after it happened. I was gonna change mine today but did'nt get the bloody chance as the bloody father inlaw dragged me up the club, willingly :lol: ................not sure about the price tho but make sure you read through your manual about it if your not fluent. Chapter 3-7 Temp gauge sender unit
i'll give that a try, must be cheaper than a fuel pump!
cheers for the help dude :thumb:
jonbuoy
Sat Aug 13, 2005 8:15 pm
E30BeemerLad wrote:by temp sensor we mean the one on the thermostat housing?
As yours is 325 then yes, it's on the thermostat housing but for the M40 it's on the left handside of the head towards the bolkhead
jonbuoy
Sat Aug 13, 2005 8:17 pm
No probs, always here to help. Hope it solves your problems, let me know how you get on, if i need to put my thinking cap on again :lol:
Skip
Sun Feb 12, 2006 5:10 pm
Did you sort this Stevo - my 316i is doing pretty much the same thing... :cry:
ex-325i Touring
Widge
Sun Feb 12, 2006 6:36 pm
I think the problem is with fuelling, and is down to one of the DME (I think they are called) relays on the front passenger wing in the engine bay, I changed mine to 3 from a scrap car and it solved my intermittent jerking problem.
Mon Feb 13, 2006 12:16 am
M40 blue sensor is hidden under the inlet manifold about half way along.IIRC, the M10 one is on the top of the head near the bulkhead.(or is that the temp gauge sender?)
