I'm Amanda, new to the forum and site. Its a great site.
I have a slight dilemma, can anyone tell me how I can tell whether I have a M5 block, crank and pistons, or a normal 325i block, crank and pistons?
Basically I've removed and stripped the bottom end. When I bought the car I was told it had a M5 bottom end and uprated head and cam, the latter it has but now need to know about the block. Can I tell off the numbers on the block or crank? The shells are out and they are standard, but is that M5 standard or 325 standard!!!!!!!!
I have currently got a standard 325i engine in the car and you can really tell the difference between the two - its well slow!
Amanda
PS I've broken 3 nails now!!!
PPS Is it me, or does old gearbox oil smell like cat pi$$!!
