325 ELECTRICS
mpower_uk
I've got an 325i E30 G reg ... just changed the alterantor, the belt and the batery, but I'm loosing electrics ... the alternator was tested and it's fine ... the battery as well but it goes dry after I use the car for a couple of hours .. Any ideas ?? Thx for help
mands
Have you checked what charge the battery is getting with the engine running? (Idle and 2,000 rpm) it maybe over charging and cooking the battery - this happened to me once, the new alternator i bought was faulty.
hope this helps
amanda
hope this helps
amanda
rickk
Just to be sure: the battery goes flat after a few hours of driving, not just from sitting?
Then I'd indeed check the charging voltage, should be 13.9V-ish.
