gearbox whirs when i select 2nd - should i worry?
Bob7
Post Fri Aug 12, 2005 7:34 pm
Hello everyone, i'm new to beemers, and this forum, and the internet too, so you'll have to bear with me a bit as i get to grips. Here's my question. The gearbox in my 325 makes a whirring noise as i select 2nd while the clutch is in and whines when i let the clutch out before applying revs, the noise fades as the load increases. All other gears are silent. Should i get it looked at? or is this to be expected. Cheers.
TOURINGDADDY
Post Fri Aug 12, 2005 7:39 pm
hi mate and welcome to the zone. firstly i'd proberly say its some thing to do with the sinchromesh and would b worth getting it looked at although i could b wrong :roll:
Bob7
Post Fri Aug 12, 2005 7:56 pm
cheers dude!
Jos
Post Fri Aug 12, 2005 8:28 pm
Welcome onboard the e30 addict site:)
Could be the baulk ring going, boxes are cheap anyway, if you can do the work yourself of course. Generally not worth doing work on a gearbox, just get one from the scrappies.
Thicker oil or sawdust should cure it in the short term :lol:
'94 e36 tree climber
