hi guys been a while hope all's well
here's the deal once my car get's warm when i stop in traffic or at the lights after a few seconds when rev's are at idle level it suddenly goes into as i can only explain (LIMP) mode where it start's to die the rev's drop and it feel's like when a cam belt or battery dies no power and nothing you can do it will die some times it will start staight away other times takes a while and i get a loud back fire from the exhaust.(FUEL)i guess.
what does a crank sensor do when its on its way out has anyone
ever had to get there's replaced
ive got no idle control valve no cam sensor where im running m/s management and changed the tps.
A-TECH(ant)
has told me to change the crankshaft sensor which i belive will work but wanted to find out some tell tale signs see if it sounds right
CHEERS PEEP'S
crankshaft sensor
318isturbo
or possible dme relay but has only been changed about 5 months ago no longer than that and was a main dealer one two anyone ever changed a dme relay and had it go so fast
