Anyone know the part number for a convert. 1990 ?
Theres a pair on fleabay which i might get as spares, unless they are cheap enuf to buy!!
rear strut top mounts
Martinaston
There is NO nucleus.
ian332isport
Not sure which ones are available on the bay, but the best (BMW) ones to fit are from the E46 M3. These are direct swap for the standard E30 parts, but a bit more robust.peanut wrote:Anyone know the part number for a convert. 1990 ?
BMW part number 33 52 6 754 096 - approx Ԛ£12 each (inc VAT) at the dealer.
Cheers,
Ian.
sabrje
If its these your looking at
http://cgi.ebay.co.uk/Rear-spring-top-m ... dZViewItem
then be aware - they are NOT rear top mounts
- they might be front ones though....
Martinaston
7 series i think
E30Mark
they are rear spring mounts for a E24 635CSi or E32 - allsabrje wrote:If its these your looking at
then be aware - they are NOT rear top mounts- they might be front ones though....
definetly NOT E30 !
have sent comment to seller!
peanut
Thanks a lot, saved me a lot of trouble.
e30bemer
- Nutters
ian332isport wrote:Not sure which ones are available on the bay, but the best (BMW) ones to fit are from the E46 M3. These are direct swap for the standard E30 parts, but a bit more robust.peanut wrote:Anyone know the part number for a convert. 1990 ?
Cheers,
Ian.
the part number has changed to
33 50 4 035 931
and are Ԛ£13.61 inc vat
bigpimpin
Sorry for the ignorance but what benefit do these E46 top mounts give you?
They are alot stronger and will last longer than 5 mins if u have an E30 which runs m-tech height or lower!bigpimpin wrote:Sorry for the ignorance but what benefit do these E46 top mounts give you?
If your car is a standard E30 on stilts then the normal ones are fine.
