Electric windows dont work
- vickers609
Hi i have recently bought a 320i convertible and my electric windows dont work. Does any one no the colours of the wires and what wires do what cheerz
- vickers609
I have cheked the fuse and the overload switch and they are both fine, I have taken the centre console out and on evry window swich there is 1 blue and 1 brown wire that has been cut and left not attached. cheerz
Do the windows work with the doors open ?
Had this problem with one of my old E30s - the windows stopped working with the doors shut but were fine with them open - reason being the wires which run into the doors had become damaged over time.
Wiggling these wires may get the windows working again but if it is this thats faulty you'll need to get into the loom from the A post into the door to find out where the problem is.
- vickers609
i will check, thanks
this is the colour scheme for the socket in the A pillar
Pin Colour Function
1 GN/WT Fuse 19 PWR to mirrors + Interior light cancel
2 br Interior light GND door handle switch
3 RD Interior light timer; central lock control PWR
4
5 BU/BK PWR passenger window motor
6 BU/WT PWR passenger mirror motor
7 WT/BK Switched PWR to passenger mirror clutch
8 BR GND central lock control, double lock
9 BU PWR/return door lock motor
10 WT Return/PWR door lock motor
11 YL/BU Lock request
12 GR/BU Unlock request
13 VI PWR window motor
14 BK PWR window motor
15 RD/BK Interior light timer; central lock PWR
16
17 RD/BR Double lock request
18 GN/WH Fuse 19 PWR interior light cancel
19 BR/GR Interior light enable
20 GY/GN Radio speaker
21 GY/YL Radio speaker
note: colours BK=black, BR=brown, RD=red, YL=yellow, GN=green, BL=blue, VI=violet, GY=grey, WT=white
note2: colours not used in all years/models, this is a general guide only!
note3: some cars have lock heaters, some have interior light timers, probably in an either or situation.
maybe this will help
Very Happy Smile Sad Surprised Eek Shocked Confused Cool cool Mad Mad Mad Razz Embarassed Cry Evil or Very Mad Twisted Evil Rolling Eyes Wink Wink Exclamation Question Idea
Pin Colour Function
4
16
- vickers609
Hi i have braught and wierd in new window plugs and cables as the old one's were shaged but still have no windows. Is there a relay or anything for them as fuse and overload switch are fine thanks
- vickers609
ok will do thanks
E30cabalan
Check the switches as well, I recently found 2 out of 4 not working as they had corroded inside and the contacts were useless. Use the good switch to test the other window motors.
Seems to be a common fault on cabs
