M42 ticking noise
Jamesb318is
Post Mon Aug 08, 2005 8:10 pm
Hi,
for a while now ive been noticing a ticking noise from my engine, which goes away when it is fully up to temp.
The speed of the ticking does increase with revs, but it isnt injectors i dont think as i can hear them ticking seperately and this noise goes away.
I have also had a good close listen and it doesnt seem to be comin from anywhere round the exhaust manifold, more under the inlet side.
Has anyone else had this?, can a shot inlet gasket tick like an exhaust one would?
Karan
Post Mon Aug 08, 2005 8:23 pm
inloet would not tick
an exhaust blow at manifold cyl no. 1 would be my bet...
however the top end could be a bit noisy until it warms up---just wear and tear i guess
has it come on sudden or gradually or always had it
Jamesb318is
Post Mon Aug 08, 2005 8:28 pm
I thinks its always had it but its just recently that ive really started to notice it.
Exhaust manifold is the best bet i know, but it really doesnt sound like its coming from there
I have a spare manifold to put on but really dont want to get involved with snapped/stripped studs etc! (although i know the answer to that Q is 'do it you lazy muppet' or something similar!)
dazleeds
old skool raver
old skool raver
Post Mon Aug 08, 2005 8:32 pm
:lol: :lol: :lol:
JUST DO IT :poke:
www.oldskoolfantasy.co.uk
Jamesb318is
Post Mon Aug 08, 2005 8:39 pm
I really have no excuse i suppose, i even have my 'own' two post ramp!
Do is heads still have a problem with stripping studs as with m20's though?
And i really dont want to go all through that only to find it still does it!!
dazleeds
old skool raver
old skool raver
Post Mon Aug 08, 2005 8:41 pm
u got a 2post as well???your taking the :piss: go do it now :lol: :lol:
just heat the studs a little first should cut the risk of snapping etc Daz
Jamesb318is
Post Mon Aug 08, 2005 8:51 pm
Well i have my own ramp at work, which i can go and use on a sat morning.
I'm digging myself deeper and deeper lol!
Anyone know a good test to see if its the exhaust manifold though? cant get close enough to tell properly
Karan
Post Tue Aug 09, 2005 12:02 am
Jamesb318is wrote:Well i have my own ramp at work, which i can go and use on a sat morning.
i believe u can get a tube.. and put one end nr ure ear.... other end to poke around and listne for noises... sounds absurd but works!
soot around primary/flange joint is a giveaway too!
Jamesb318is
Post Tue Aug 09, 2005 2:03 pm
Good idea! I'll give it ago
