crank from 525e question
bigdek
Does it matter what year of car its comes from for the 2.7 conversion
Widge
The cranks are all the same, the year may only affect the car if it is an 87-88 super eta, in which case the pistons and the head are different to normal eta's. These super etas have very similar piston and combustion chamber shapes to a 2.5 so they make good 2.7's
bigdek
sweet just bought 1 for Ԛ£30
Widge
Damn you
I thought I had the cheapest ETA crank in the land!!!!!!!!!!!!!!
What's the plan with it, cos it won't just bolt in !
bigdek
Not sure yet m8.
New it was a bargain so scooped it immediately.
thinking of buying another sport or an se thats needing work done to it and use the head and block , 320 rods , shrick cam ,bbtb, zone chip , manifold , exhaust.
As i said not sure though as i'm just gathering info on what i need and how to do it.
Not in a hurry so hopefully can pick up a few more bargains and keep the cost down
Widge
You'll need to deck the block by 3mm (approx) and have the skirts of the 2.5 pistons machined so they clear the counterweights on the crank. And you'll need a vernier pulley to set the timing right after you have decked the block.
bigdek
yeah read that somewhere already m8
Not too big an isssue though
Widge
I have been told by my local machine shop that machining pistons it not cheap as they are quite fiddly and require a lot of setting up so they are all identical.
bigdek
got a m8 who is a cnc turner so he can do that bit for me
Widge
Lucky bugger
