Spent last weekend with my cluster (turning the house into a warzone, tools and parts all over the place, as usual
I was also determined to repair the MPG gauge, which has never worked ever since I got the car. When I got it, the speedo and MPG gauge were dead. I fixed the speedo pretty quickly by cleaning contacts and reflowing some solder joints, but the MPG only works about once or twice a year when it's very hot outside.
So, this weekend, after installing the rings and painting the needles, I reflowed some more joints, cleaned more contacts, measured continuity, etc. Also, inspected SI batteries which seem fine (no leakage, good voltage readings), but after putting everything back together it's still dead
To top it off, my speedo is now 15 km/h (that's about 10 miles/h) off when I set the park position to the first stripe (which seems to be the stock position)
Could this be due to the added weight of the paint or something? Is there are nicer way to fix it then just moving the park position to 25 km/h (which sucks, IMHO)? Any ideas on the MPG gauge?
Thanks,
Rick
