E30 change over year?
stappin
Right I have two E30 325i's one that im canibilising to make the other one into a rally car.
But they have different injection and ignition systems. One is a D reg and the other an E plate. Now was there a change in the model as the later one (E reg) has a different ignition setup and all the other lecy bits are Bosch?
So was there a change in the E30 model electrical setup between D&E reg and if so what was different?
Big changes. Early is jetronic, later is motronic.
Engines complete with electrics are inrechangeable, or you can fit all the sensors, along with the rest of the electrics to the other engine.
Ziggy
Don't like to question Brian (& I expect that means I'm wrong
), but I thought it was just early 2.0s and 2.3s that had jetronic, & all 2.5s were motronic? Different ecus & motronic 1 vs 1.1 for the facelift? Something like that?
- Homo Hair
fit the earlier lump with the later management...
Just a guess on my part,and half remembered stuff. I'm no expert on the pre facelift stuff.Ziggy wrote:Don't like to question Brian (& I expect that means I'm wrong), but I thought it was just early 2.0s and 2.3s that had jetronic, & all 2.5s were motronic? Different ecus & motronic 1 vs 1.1 for the facelift? Something like that?
stappin
What gain will this give?Jhonno wrote:fit the earlier lump with the later management...
So are they all the same type of injection management?
- Homo Hair
its better management - you have to swap the complete loom over
stappin
But why use the earlier engine with it?Jhonno wrote:its better management - you have to swap the complete loom over
- Homo Hair
earlier engine is higher compression
- Homo Hair
and tend to make better power
dazleeds
- old skool raver
sorry to butt in but anyone got a full guide on what you swap from the motronic onto the early lump???
as i have a 323i going to waste here would make a nice conversion and not too hard by the sound of it cheers Daz
www.oldskoolfantasy.co.uk
Turbo-Brown
- Boost Junkie
If it's any help, my '85 325i had a Motronic ECU (it's on a C plate)
A1BMW325iSport
all 325i`s were Motronic its just the later ones use a diff version
Matt
Matt
Dan318-is
motronic? jetronic? wha?!?!?
