prob with central locking
carlos_320i
Post Sun Aug 07, 2005 4:22 pm
If you try to lock the car from the drivers door it only locks the drivers door put the other side will lock all the car has any one got any idea :? :?
Post Sun Aug 07, 2005 8:00 pm
Could be the yellow/blue "lock request" wire pin and socket in the drivers door hinge pillar connector, but I would think it more likely that the linkage from the drivers door lock to the locking motor in the door is somehow worn and out of adjustment, not pushing the arm in the motor far enough to work the lock request switch.
carlos_320i
Post Sun Aug 07, 2005 10:07 pm
Thanks for your reply is it easy to repair??
