can sum1 pls help
battery running flat
fiky
hi guys ,ive got a problem where my battery runs flat about after 2 days of the car not being used im always dissconnecting the battery everyday
this is driving me mad,ive tried to find out what it is but just cant seem to find anything
can sum1 pls help
can sum1 pls help
DeeDee
Generally one of two things. Most likely the battery needs to be renewed as it is not charging/holding charge. Second your alternator is working inefficiently. You can check the alternator first by getting a multimeter across the battery terminals when the car is running.
- **BANNED**
If both of these check out fine try disconnecting the boot light,it may just be staying on and is very difficult to check that it is going off when the lid is closed.DeeDee wrote:Generally one of two things. Most likely the battery needs to be renewed as it is not charging/holding charge. Second your alternator is working inefficiently. You can check the alternator first by getting a multimeter across the battery terminals when the car is running.
Youth is wasted on the young.
jmc330i
Or the glove box light.daimlerman wrote:If both of these check out fine try disconnecting the boot light,it may just be staying on and is very difficult to check that it is going off when the lid is closed.DeeDee wrote:Generally one of two things. Most likely the battery needs to be renewed as it is not charging/holding charge. Second your alternator is working inefficiently. You can check the alternator first by getting a multimeter across the battery terminals when the car is running.
The boot light isnt difficult to check - chuck someone in the boot and shut them in, if they start screaming to be let out cause its dark in there, its a fair bet the switch is working - (its best if its someone you know, not a random pedestrian, I used my brother)
Someone on here did suggest using the video facility on their phone to see if the light was going out.
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
cougar
