Lumpy idle problem until warm...
I have a 1990 316i...when the car is started from cold in the morning it kicks in and then the revs fall to around 500rpm and it cuts out. I can stop it from cutting out by keeping the revs up for a minute or so (it sounds and feels lumpy whilst doing this) and once the engine is warmed up the idle returns to normal levels and feels much smoother...any ideas?!
Same problem with my 325. Only lasts a minute and no amount of pumping the accelerator helps keep the revs up. But after that its absolutely fine and sits at idle really well. Talking in to be looked at this week.
bobbin1982
OMG sounds like the cutout bug......they warned us about this when the millenium started
Driving my digger!!!!
Suggestions:
Remove and clean out the ICV with brake cleaner
Check the rubber air intake elbow for splits - visually and spray WD40 over it and listen for an engine note change. Also spray some over the pipe which goes from the rocker cover and under the inlet manifold.
If it's still bad it would be worth investigating or just replacing the engine temperature sensor which is blue and bolted into the thermostat.
What he said!toby wrote:Suggestions:
Even though it seems strange to me that it should run smoothly when it's warm, I'd still check the most obvious things first - air intake and ICV. If you can eliminate these as not the cause of the problem, it's best to do so, otherwise you may spend weeks and £££'s trying to figure it out, when it could be something very simple.
