fuel gauge does not work
fiky
Post Sat Aug 22, 2009 12:03 pm
yeah another thing my fuel guage does not work shows full most of the time works now and then but mostly shows a full tank
m_jermyn
Post Sat Aug 22, 2009 12:19 pm
does it move when you tap the cluster? There is 2 small 8mm brass nuts on the back of the instrument cluster. One is for the fuel gauge an the other for the temp gauge... Try tightening the nut, Its a earthing point so if its loose the gauge wont work properly. When you hit a bump or tap the cluster the jolt can be enough for it to earth thus making it work.
There is other reasons however.
Mike
fiky
Post Sat Aug 22, 2009 12:24 pm
ok cheers for that i will try
fiky
Post Sun Aug 23, 2009 2:07 pm
hi ive got a G REG 320I
m_jermyn
Post Sun Aug 23, 2009 2:31 pm
Whats a G reg?? We that are not in the UK dont understand your rego numbers.... What year is it? :mad:
JWaller360
Post Sun Aug 23, 2009 2:38 pm
G is 1988/1989 I think, so should be Facelift.
