Wiring loom door?
Post Wed Aug 12, 2009 9:00 am
I've just changed my drivers door and plugged it all in. The door lock has not been installed yet, but the central locking is not working anymore.
Post Wed Aug 12, 2009 3:10 pm
bump
Post Thu Aug 13, 2009 4:07 pm
I found the problem which is a corroded connector. So swapped in my other door loom which was working before and there is one connector which I don't know where to plug?
Drivers door.
PG325
Post Sat Feb 13, 2010 9:30 am
Blitz wrote:I found the problem which is a corroded connector. So swapped in my other door loom which was working before and there is one connector which I don't know where to plug?
Drivers door.
Did you find out where this wire attaches to as I have the same query in a different post.
