Touring Rear Discs
takamichinoko
Fri Aug 07, 2009 3:36 pm
Simpleton question, apologies....
Can you fit touring rear discs to a 2dr saloon? If so is it bolt on bolt bolt of or do you have to make changes to get it to fit?
Thanks :D
12345kevin
Fri Aug 07, 2009 3:45 pm
Ideally you'll need the complete trailing arm assembly with handbrake cables. This can then be swapped with yours easily.
town325i
Fri Aug 07, 2009 6:30 pm
yes they will fit straight in but you will need the arms
