Front bearing
steve_000
Thu Aug 06, 2009 12:39 am
Right quick one, when i get to 40 there is a rumble from the front passenger side, then it goes at 45, then appears again about 75.
I have history to say the bearing has been replaced 2 years ago, possible for it to be the suspect?
Also a whine from the rear, more a mechanical noise, like, metal slightly touching metal to create a grinding noise. Nothing serious though, only happens on movement and gets slightly faster as car get faster.
Is that the diff?
Cheers for the help!
