RE: Rear brake protector plate removal and fitting
Jason318is
Sat Aug 01, 2009 9:38 am
Hi all,
i'm planning to strip and make good the handbrake pad assembly on my 318is and I want to replace the protection plates are there pretty rotten - I just wanted to know if the plates can be removed easily once the handbrake bits are removed or do you have to remove the wheel bearing etc??
cheers
jay
simonsimoff
Sat Aug 01, 2009 10:02 am
Yes you have to pull the hub off to remove them in one piece.
