alright peeps! I have found that my headlamp adjusters dont work, what could be the problem with them?
also what is the fluid tank which is located in the OSR wing by the petrol tank pipe? cheers
fluid tank and headlamp adjusters
Bob_S
smithy318i
Headlight adjusters rarely work. the liquid leaks out. tou could do an e36 electric conversion, but imo it aint worth bothering with.
The plastic tank is an expansion tank for fuel/ gasses (i think)
sabrje
There's been some previous threads about this, such as http://www.e30zone.co.uk/modules.php?na ... highlight=
The upshot is that not much can be done to repair the existing system as its so fragile. However, I've just spent the weekend taking out the old system and installing a brand new one I got cheap on fleabay.... Pig of a job, but its all working now....
gazza
you can buy the replacement pipes (already filled with the fluid from the dealers for about Ԛ£35 they can be repaired but its a hell of a job normally to find the leak without stripping the whole lot out first
Templ8e30
My adjusters have stopped working, the piston assemblies on the back of the lights are cracked and leaking
I went to the local BMW dealer on friday last week and he said the hydraulics parts are no longer available so I've ordered a set of manual adjusters for Ԛ£12 instead.
Cheers,
Iain T
Cheers,
Iain T
2007 Mazda 6 2.0 estate
tourer-dan
They're still available as a complete sealed unit for I think Ԛ£112.
I got a set off ebay cheap so they do come up. I haven't fitted it yet though........
A1BMW325iSport
Ԛ£87.56 is the exact price as of 2 weeks ago when i asked, the old part number which was cheaper is NLA
