E30 M3 dashboard instruements
ocallen
Post Mon Aug 01, 2005 10:29 am
Is it a simple job to fit the rev counter, or the oil pressure gauge and red needles, from a M3 into a 325.
A1BMW325iSport
Post Mon Aug 01, 2005 11:09 am
make sure you try and get the rarer MPH version, change coding plug for your 325i one, also have the oil filter housing drilled and tapped for the oil sensor or fit the sensor in place of the sump drain plug.
Matt
