Sounds like there is a mouse right behind the steering wheel!
Anyone ever had this?
Any ideas?
Andy
My steering colum squeeks!!!!!
Andy325i
Karan
prob the upper bearing if its in the column byt more likely a shroud/trim related issue... my old one did it
stevo
would it be the bearing if theres a kind of groaning, grinding noise when going to opposite lock when staitionary?
johnono
what if it just needs an oiling
stevo
its one of these things where every time it happens i think "i'll look into that" but forget all about it 2 mins later
jigjags
try putting a bit of cheese on your indicator stalk ....coax the little fella out..!
Or check your power steering reservoir is filled to the mark..!!
johnono
jigjags wrote:try putting a bit of cheese on your indicator stalk ....coax the little fella out..!
Andy325i
Powersteering pump is S H A ** E D
But this is actully comming from the top of the colum
Karan
its 100% trim around the steeringAndy325i wrote:Powersteering pump is S H A ** E D
dobbie82
- Location: Dolgellau, Wales (NOT A TRADER,broken a car,got lots of bits)
my steering wheel mouse only wakes up when the car has been in the baking sun for a while..
johnono
if u grease the horn contact (copper ring on the under side of the steering wheel) then the mouse should move house
