Can I clean the idle control valve with brake/carb cleaner?
Adil786
Tue Jun 30, 2009 8:39 pm
I think I may have a sticky idle control valve ICV on my m20b25 lump since disconnecting it has minimal impact on the engine idle (my assumptions are open to criticism!)
I read that I shouldn't clean the ICV since it affects the friction and hence opening/closing performance.
Is this really the case? Anyone with similar experience?
baptie0
Tue Jun 30, 2009 8:47 pm
brake cleaner will be fine to clean the ICV.
owenbach
Tue Jun 30, 2009 8:50 pm
i cleaned mine over a year ago with brake cleaner icv still working fine
Grrrmachine
E30 Zone Wiki / Team Member
Tue Jun 30, 2009 10:07 pm
What's the best method to test the ICV? Just unplug it?
Adil786
Wed Jul 01, 2009 1:23 pm
Grrrmachine wrote:What's the best method to test the ICV? Just unplug it?
I found the original link about not cleaning the ICV:
http://www.verrill.com/car/e30_idlefaq.shtml
It tells you how to check the ICV.
But this also tells you not to...? I'm going to clean it anyway, cos the friction from the valve can't be any less than when it was new if I clean it out!
Wed Jul 01, 2009 3:32 pm
Unplugging the ICV an a running E30 engine shouldn't make any immediate difference at all!
The idle speed will only change if there's a significant change in the load on the engine.
The ICV is part of a closed feedback loop,so if the engine is idling at a steady speed, there will be no signal to the ICV.
