Rear Wishbone
denzil318
Fri Jun 12, 2009 10:58 am
Tha car just failed mot with a hole in the drivers side rear wishbone...
Does anyone know if a wish bone off the back of a 325 will fit on a 318 is?
if its not rear wheel, i dont want to no.
**BANNED**
Fri Jun 12, 2009 12:22 pm
Presume you mean the trailing arm,my understanding is that all disc braked rear ends are the same,but the arms from drum braked cars are a little different.
Youth is wasted on the young.
Fri Jun 12, 2009 2:57 pm
318is, 325, all cabs, all E30s with ABS and all tourings have the same trailing arms.
How on earth do you get a hole in a trailing arm, if that's what you mean?
denzil318
Fri Jun 12, 2009 3:30 pm
I dont know, the mot tester poked a hole through it, yes i presume its the trailing arm, it carries the disk, the caliper, the drive shaft ad the rear wheel bearing and everything else on the rear...
Fri Jun 12, 2009 9:58 pm
It's made of painted steel, so it has the potential to rust, but I've never seen one with anything more than the lightest surface corrosion in a few areas!
In spite of what I wrote in my last post, all arms are not quite the same - If your car has ABS, you'll need one from an ABS car, which will have the fixing hole for the sensor. If your car doesn't have ABS, then either type will do.
