Just cuts out
Spike121
Thu Jun 11, 2009 3:31 pm
Hi Guys,
I have a 1990 325i auto cab, the car has been running without any problems at all, this morning the car fired up as normal (ticks over about 750) drove for around 15 miles and the first time i took my foot of the throttle the car cut out! it fired up no problem but it keeps cutting out when i dont give it some extra revs :cry: Can any one shed some light on this please. I have checked all the pipes/hoses and have no air leaks.
It`s a state of mind.
Morat
Thu Jun 11, 2009 4:09 pm
Have you had a flat battery recently?
Things to check: Idle Control Valve, Throttle Position Switch.
How did you check the pipes and hoses? If it was just a visual inspection then you might have missed a tiny crack somewhere. Does the idle change if you remove the oil filler cap?
Spike121
Thu Jun 11, 2009 4:15 pm
No flat battery, i took the pipes off done a visual check and when the engine running sprayed with wd 40, took the oil cap off and the revs dropped. thanks for the quick reply.
Spike121
Mon Jun 15, 2009 6:01 pm
Morat, thanks gave the icv a good clean and the car keeps its revs when slowing down :D just got to sort out the niggly dead spot when she`s cold. will take it for a tune up, cheers.
