2/ is a close up of the multivalve in the tank
3/ is the tank in the spare wheel well, also showing the ex Volvo space saver spare wheel and the 10mm thick plywood strips glued under the loadspace floor to raise it slightly to clear the tank
4/ is the air filter/AFM, showing the gas inlet into the air box, the gas flow electric control valve and the AFM "bladesaver" backfire device.
5/ is the water pipes for the reduver, teeing into the heater pipes
6/ is looking down onto the reducer mounted on the chassis rail. Air filter has been removed for a better view.
7/ is the LPG filter/solenoid valve on the suspension turret. Relay cover has been removed for a better view.
8/ is the gas mixer venturi plate in the top of the air filter box
9/ is the "bladesaver" device, showing the brass "catflap" and the black rubber band that allows backfire pressure to be released.
