Hi,
Recently been having a problem with the driver's side electric window on my 94 touring. The window goes down fine but when I try to put the window back up it keeps stopping. I have to keep putting my finger on the switch and even then it only just creeps up (very slowly).
Wondering if it may be a faulty switch or some sort of wiring problem?
Cheers,
Peter
Touring Electric Window Problem
- Brianmoooore
Faulty switch is most likely.
Swap it with the passenger one as a test, then, if this cures the problem, open it up, clean it out, treat it to a smear of silicon grease, reassemble, and put it back in.
Because of the way they sit in the car, they tend to get full of dirt/pins/aluminium foil, etc., over the years.
