wheel help
e30jamin
Sat May 30, 2009 8:28 am
one of my wheels on my new cab had a crack in it took it to get fixed but they guy said the weld wont take to it not good so i need a ap motorsport wheel any ideas where i can get one?
into my dubs was thinking if i cant get a wheel ill put some deep dish wheels on it do mk2 golf wheels fit strait on e30's?are all e30 4x100? cheers :cool:
Grrrmachine
E30 Zone Wiki / Team Member
Sat May 30, 2009 10:18 am
As far as E30/VW wheels go, the PCD and central bore are the same (4x100, 57.1mm) but the offset is usually different. E30s need a max ET25, whilst VWs are usually around ET38, so there'll be some rubbing.
e30jamin
Sat May 30, 2009 10:38 am
cool mate so anything et25 or less will fit ?cheers mate
Sat May 30, 2009 9:32 pm
Yes mate. Ideal offset for 9J wheels is 15 i believe :)
hongkongfuey
Mad-tango-geezer
Sat May 30, 2009 9:58 pm
i've got a set of azev 'a' wheels (for sale winkeye ) which are 7.5j 16" et35 , the rears fit with 205 tires without rubbing any bigger and they rub on the inner arch, i put on 15mm hubcentric spacers and had 225/40 tires on with no issues. but they won't fit on the front without spacers
with cars like mine,
