Eezi-bleed?!
SammySmack
Fri May 22, 2009 1:43 pm
Hey people,
Just about to bleed the pipes, so my mate has given me his 'eezi-bleed pneumatic bleeder', bless him.
So how on earth does that work then?
Ive got two bottles, a pipe (or two) and a valve!
Do i need a spare tyre for this one, or an actual compressor?
smithy318i
Fri May 22, 2009 2:22 pm
Pretty easy to use.
attach it like this.
put new brake fluid into the bottle.
attach other end to your spare tyre (at 20PSI ish)
open each of the bleed nipples in sequence until new fluid is seen through the pipe.
keep an eye on the fluid level in the bottle/reservoir.
bleed sequence is:
Rear right
Rear left
Front right
Front left
smithy318i
**BANNED**
Fri May 22, 2009 2:30 pm
Dead easy to use,hardest part is opening the bleed nipples.
Youth is wasted on the young.
gareth
Fri May 22, 2009 3:09 pm
if you have an old wheel / tyre, use that instead of the ones on the car. if you're stoopid (like me) it's possible to get brake fluid inside the tyre :o:
SammySmack
Fri May 22, 2009 3:12 pm
Cracking replies, cheers fellas....
But my problem is that the eezi-bleed my mate has given me is not the pictured by Monsieur Smithy!
Its the pneumatic one, well this is what it looks like anyway.
http://www.gunson.co.uk/item.aspx?cat=674&item=3448
Looks a bit complicated to just bleed brakes!
Anyone know how this one works?
cougar
Fri May 22, 2009 7:39 pm
i think this needs a compressor ,but i could be wrong
current cars, 4 e30 tourings, 2 e30 cabs, 1 e36 328i sport, 1 e36 328i cab
Fri May 22, 2009 11:11 pm
indeed, that does look like it needs a compressor, unless there is an adaptor to hook it up to a car tyre
SammySmack
Tue May 26, 2009 11:15 am
It turns out it is compressor based.
All good, I just bled the brakes the good ol' fashion way with a pipe and mate on the brake pedal!
Thanks for the help anyway, makes me feel a bit dumb to ask as stupid question like that, but hey ho!
Nice One!
