M20 325 HEAD
boydy
Tue May 19, 2009 11:13 pm
hey guys, bought one of these off e-bay, needs the cam shaft and rockers put in, is this hard to do?
Tue May 19, 2009 11:17 pm
If it's from ebay, the first thing is to get it crack tested and checked for flatness!
boydy
Wed May 20, 2009 7:28 pm
yeah got that done brian, what next? cheers for info
Wed May 20, 2009 10:23 pm
Cam in first, then push the rocker shafts in, threading the rockers on as you go, with the adjuster eccentrics either turned fully in or removed. Keep the rockers off of the valves, and by turning the cam, you can slide it all together.
Move the 'loose' rockers onto the cam lobes, and fit the clips, turn the cam, and slide the remaining rockers in place.
Finally, fit the locking plate for the rocker shafts, and turn the cam pulley to line up the timing marks.
boydy
Thu May 21, 2009 7:08 pm
cheers for help brian
