engine upgrades
kitch
Fri May 08, 2009 8:05 pm
ive got a 320i prefacelift and was just wondering if there are a few things to gain a bit of power, dont want the hassle of swapping engine, not after that much power, but thought that a 2.5 tb or something might make it a bit better??
any advice is wellcome, thanks :)
hongkongfuey
Mad-tango-geezer
Fri May 08, 2009 11:01 pm
if you put on a 325 throttle you will have to grind back the manifold a bit so the butterfly doesn't foul on it, then a chip would help
with cars like mine,
Reflex
Fri May 08, 2009 11:07 pm
chip deffo
There Was A Time Last Year When I Was 17, But I'm 19 Now... And Things Have Changed
http://photos-h.ak.fbcdn.net/photos-ak- ... 778999.jpg
Fri May 08, 2009 11:08 pm
Short answer is no! You can tinker at the edges to make minor improvements, but what's the point? It's not like the 2.0 has any worthwhile advantages over the 2.5.
A swap to a 2.5 is hardly difficult - certainly no more hassle than most 'improvements' that may be worthwhile.
There's nothing wrong with the 2.0 engine, but it's an engine to be enjoyed as it is, or removed and replaced by a 2.5 upwards.
