Clutch
adam3442
Post Thu Jul 21, 2005 7:02 pm
First and foremost, soor if it seems as if I only come on here for tech help, I'm always on here but don't post alot..
Anyways..
My 1990 320i cab is juddering when I pull off in first or when I reverse, it's bloody embarassing .. However if I pull off in second it goes ok, even when I give it more revs in first it calms down but still judders..
Any ideas, as I've only had this car for under three weeks and all i'm getting is problems so far, and the car was mint..
Many thanks in advance!
Dan318-is
Post Thu Jul 21, 2005 7:17 pm
either ur 1st gear is chipped, very unlikely tho.
if not some sort of clucth problem, maybe release bearing damaged or pressure plate worn? they would be the likely options altho im sure other users on here have far more knowledge about transmissions that i do
adam3442
Post Thu Jul 21, 2005 7:19 pm
How hard is it having the gearbox out on an e30, and how hard is it to change the clutch etc?
I'm not a bad diy mechanic but still learning...
Dan318-is
Post Thu Jul 21, 2005 7:30 pm
likewise my friend.
i would imagine fairly hard, it all depends on if you haev the right equipment i think. its always best to determine the cause first, thats what iv found out lol
adam3442
Post Thu Jul 21, 2005 8:53 pm
Yeah i'll deffo try and find cause first, cheers mate.
Anybody else got any ideas?
slideways
Post Thu Jul 21, 2005 10:42 pm
if its judderin it could be the springs in the clutch sisk worn/broken
could we have been doing circles???
Post Fri Jul 22, 2005 12:01 am
Could be oil contamination of clutch, broken clutch bits or worn clutch, but check the condition of the rubber guibo on the gearbox output flange, the propshaft centre bearing mount, or even the gearbox rubber mounts before you get to involved.
adam3442
Post Fri Jul 22, 2005 9:14 am
If it seals on the Gbox can these be replacved without having it out?
I haven't been doing circles, i'm too scared it will break :?
Post Fri Jul 22, 2005 9:46 am
Won't be the gearbox seals causing oil on the clutch plate, it'll be the engine rear crank seal.
This is a gearbox out job,or engine and gearbox complete. You'll have to take the gearbox off to change the clutch plate anyway.
Not particularly difficult, but you'll be lifting around some hefty lumps of metal, and of course, there are loads of "while you're in there" jobs.
Demlotcrew
Post Fri Jul 22, 2005 10:03 am
Brianmoooore wrote:Won't be the gearbox seals causing oil on the clutch plate, it'll be the engine rear crank seal.
Selector rod bushes come to mind! :lol:
A
jmc330i
Post Fri Jul 22, 2005 11:11 am
Brianmoooore wrote: Not particularly difficult, but you'll be lifting around some hefty lumps of metal, and of course, there are loads of "while you're in there" jobs.
How about the Z3 Shortshift whilst youre in there.
I remember on the old E30zone someone removing the gearbox on their driveway. A trolley jack, axle stands and there was something about a skateboard, I would guess for moving box around on :lol:
James
'91 325i Sport
'93 318i touring 16v
Post Fri Jul 22, 2005 11:40 am
I changed a 325 gearbox a few years ago (pre four post ramp days!) on axle stands and a trolley jack. Wasn't to bad.
Worst thing was all the crap dropping on you all the time.(Keep mouth closed)
adam3442
Post Fri Jul 22, 2005 1:06 pm
Looks like i'll be buying myself a skateboard! :wink:
johnl320
Post Fri Jul 22, 2005 6:49 pm
sounds like you already have :lol:
only joking
Gwynleym10
Post Fri Jul 22, 2005 7:19 pm
I ve replace my gearbox on my car on axle stands! on a drive way!
i found the most difficuly part was lifting the gearbox back up, as you couldn't put it on a jack and roll it under the car as it wouldn't fit! Balancing a gearbox onto a jack undernearth a car is easer said than done!
I ended up using some bit of wood as leavers, some bricks and the jack... worked in the end after lots of swearing.
Dual wheel carriers -------195litre Fuel Tank
London 2 Cape Town
www.Overlandinthesun.com
