How do you cure sqeeling and clunking brakes?
kevin316i
Post Thu Jul 21, 2005 6:42 pm
The brakes have started to squeel a bit when applied lightly and there is also a clunk sound coming from the back when the brakes are applied.
Any ideas on how to cure these?
Thanks,
Kevin.
jamesroools
Post Thu Jul 21, 2005 6:44 pm
squealing probably means your discs and pads are glazed over, take the brakes apart and using a fine grit sandpaper, clean the discs and pads, rebuild the brakes and use plenty of anti-squeal compound on the back of the pads, not on the braking surfaces 8O
Image Image
Dan318-is
Post Thu Jul 21, 2005 6:45 pm
:yeahthat: copper grease on the BACK of the pads often helps squeling. taking them apart and cleaning them with cleaner then replacing them often gets rid of residue and dust etc
as for the rear clunk, all i can suggest is dodgy callipers mate if its a clunk
hope this helps
jamesroools
Post Thu Jul 21, 2005 6:48 pm
i think he has a 316i mate, if so it'll have drums on the back
Image Image
Dan318-is
Post Thu Jul 21, 2005 6:51 pm
hmm
in that case, i would say your release springs have had it. dnt think what else it would be. Take it apart and look
drums are a bastad to work on tho
jamesroools
Post Thu Jul 21, 2005 6:52 pm
318-is wrote:drums are a bastad to work on tho
got that right, and there crap too
Image Image
kevin316i
Post Thu Jul 21, 2005 6:53 pm
Thanks for the feedback guys. I now have a 318iS, so it is callipers at the back. Its going into the garage tomorrow so I'll get them to check the callipers.
Hope he does a better job than the one he did on Monday. He put in a new fuel vent pipe but kinked the hose attaching it, so the car cut out on me on a roundabout!!! I nearly had a heart attack. :roll: Managed to get it back to the garage and get it fixed, properly this time.
Dan318-is
Post Thu Jul 21, 2005 9:07 pm
fookin hell. i wud have twatted him for that! cowboy mugs there is just too many these days.
good luck mate!
kevin316i
Post Thu Jul 21, 2005 11:06 pm
The thing is that he's not a cowboy, I have been going to him for the last 10 years. This is the second time he's f****d up, which I suppose in 10 years aint bad, but the consequences could have been very serious, especially as I had the kids in the car with me.
