cheers in advance
stevo
oh its an m40 318i
checked that, i even replaced all the 10amp ones with the proper 7.5amp fuses stated in the owners handbookjamesroools wrote:make sure your using the right fuse to start with![]()
http://www.e30zone.co.uk/modules.php?na ... 0fuses.htm
other than that i dunno mate
Electrics wouldn't short out if the whole door was underwater.jamesroools wrote:could be a bit of water/moisture in the doors causing the window electrics to short out
they dont blow when the windows moving, i usually find they go down then wont go back upBrianmoooore wrote:Electrics wouldn't short out if the whole door was underwater.jamesroools wrote:could be a bit of water/moisture in the doors causing the window electrics to short out
First question - Do the fuse(s) blow if the window switches are not touched, or only when the windows are moving?
2nd question - Do you have an electric roof?
3rd question - Electric windows on rear doors? If four door of course.
could be actually, i think its the passenger side that blows the fuse.Brianmoooore wrote:So do you think the fuse blows when you push the up button? If so, is it only the driver's window?
