On the above image, as far as I can tell, the plug circled in red goes into the special equipment connector behind the glovebox - is this the feed from the brake lights? The Green circled one is an earth (is there somwhere to connect this to or do I have to remove the connector and earth it manually?). The blue one, I'd guess, is for the clutch switch? But I can't figure out what this plugs into?
To add to my confusion, my kit came with two switches, pictured below.
Should I be using both of these - one on the brake and one on the clutch? I would've thought I'd just need one of them on the clutch, and the existing brake light would be fed through to the control unit somehow. Which one is the clutch switch? As well as being different connectors/colours, the red button one is a push-to-make and the black is a push-to-break switch.
Can someone please put me out of my confused state?
