issue with shifter
marchad
Post Tue Jul 19, 2005 8:51 am
hi im having a problem with my shifter it keeps rubbing on the sid of my console when i put it in reverse
Any ideas of what i could do to fix it and we just changed transmission mounts they were sheered
Demlotcrew
Post Tue Jul 19, 2005 10:55 am
Its a prop off job!
Quite hard but do a search and you will come up with a few resutls.
A
PeteE30Tourer
Post Tue Jul 19, 2005 1:15 pm
Marchad - i'm going to move this to the Tech Section as you'll get a better response there hopefully.
rowemeister
Post Tue Jul 19, 2005 2:01 pm
Some of your linkage bushes have worn mate. They need replacing.
325i Sport with Hartge H27 lump
Templ8e30
Post Tue Jul 19, 2005 6:27 pm
Have a look in the tech articles http://www.e30zone.co.uk/modules.php?na ... echnz3.htm for the Z3 short shift mod.
If you don't fancy doing the short shift mod (it is worthwhile) then replace all the other parts on the list and you'll have a nice slick gearshift without the wibbly wobblyness :D
Cheers,
Iain T
2007 Mazda 6 2.0 estate
marchad
Post Tue Jul 19, 2005 8:04 pm
what linkage bushings do i nedd to replace the ones on the transmission or the ones connected to the shifter or both
Templ8e30
Post Wed Jul 20, 2005 2:00 pm
The main culprit will be the gear selector rod joint, it sits on the end of the gear selector shaft on the back of the gearbox but you might as well change the lot while you have it in bits.
Cheers,
Iain T
marchad
Post Wed Jul 20, 2005 6:59 pm
ok well thanks for all your help guys
